Author Topic: Noob question - Why isn't the default segment aligning properly  (Read 7066 times)
TS4778
« on: September 12, 2017, 08:53:42 am »
Trying to create roof tiles with a simple offset, but the segments are not aligning correctly. How can I fix this? I'll post more screenshots of settings if needed
Re: Noob question - Why isn't the default segment aligning properly
« Reply #1 on: September 15, 2017, 01:01:22 pm »
Normally I would do this by sequencing a full size then 1.5 size tile in the left and right inputs. Just make sure that you set the sequence operator to Increment on Y.
Attached is a file with a typical setup for this sort of style. I hope that helps, please let me know if you have any further questions.
Many Thanks,
