Author Topic: Railclone Lead Flashing  (Read 9248 times)
PX2937
« on: July 07, 2024, 11:12:22 am »
Hey! I've built a railclone preset for some flying links, but im abit stuck as to how i can create an extruded area of the lead which intersects the strip of extruded bricks (see attached screenshots, screen shot of lead in place is my old method of manually modelling the links) The bricks strips vary from plot to plot so i'd ideally need to be able to adjust the lower and upper clip of the extrude and also clip it the the angled lead that sits against the wall. An help would be appreciated!
Re: Railclone Lead Flashing
« Reply #1 on: July 08, 2024, 10:25:21 am »
Hi, Could you use marker? The attached file show a possible solution using markers to place the extruded flashings.
Many thanks,
PX2937
« Reply #2 on: July 11, 2024, 08:32:26 pm »
Hey, thanks for the help! So the flashing is included in the railclone I made, but im just needing to add thicker flashing that covers the horiztonal strips of bricks while still keeping the staggered lead profile which is up against the main wall, these strips vary in height throughout builds, the way i currently have it set up is having a seperate railclone with thicker flashing only and just slicing above and below.
« Reply #3 on: July 12, 2024, 12:08:25 pm »
Thanks for the extra information, if possible, it might be easiest to see what you already use so I can adapt it. If you prefer not to post it on the forum, please feel free to send it to helpdesk@itoosoft.com.
Many thanks,
