Author Topic: Renderslaves dont render Maps of Library items  (Read 4517 times)
M55
« on: February 15, 2018, 11:59:05 am »
Renderslaves don´t render maps of library items.
after the problem occured i deinstalled 3.10 and reinstalled 3.09 on my workstation and on the renderslave.
i opened up max on both and told them to add the path
did not help
somehow the path must be screwed up
i also installed forestpro latest beta ... that seem to work fine ... but is it possible that it ruined my railclone install ???
« Last Edit: February 15, 2018, 12:06:39 pm by M55 »
Re: Renderslaves dont render Maps of Library items
« Reply #1 on: February 15, 2018, 03:14:23 pm »
I would suggest you check this related FAQ post. Mainly, please double check the [BitmapDirs] part of the 3dsmax.ini file (storing the Customize > Configure User Paths > External files paths configuration). Using UNC paths is highly reccomendable too. Hope that helps.
M55
« Reply #2 on: February 15, 2018, 04:18:27 pm »
Thanks Michal,
i had to kill my ENU directory ... that finally did it ... sometimes only the hard way helps
