Author Topic: help railing style  (Read 3245 times)
leonardo.afanador
help railing style
« on: December 14, 2018, 11:44:00 pm »
hello support,
Could you guy help me fixing this railing style?
I have problems on the corners and couldn´t figure it out how to include the glass.
thank you in advance!
Re: help railing style
« Reply #1 on: December 17, 2018, 03:30:56 pm »
How do You want this railing to behave on smooth part of the curve?
I see You have divided railing to many segments, but not glass. It should be the same level of subdivisions.
Generally Glass segment should be put to default slot.
Do You need this style to be adjustable? If it is fixed like in Your attached pdf, then You could use much less segments then You are already using.
leonardo.afanador
« Reply #2 on: December 17, 2018, 03:37:40 pm »
hi rokas,
I need to be adjustable because it will be replicated in different parts of a building.  stairs, balcony, corridors.
How do You want this railing to behave on smooth part of the curve?   I need the railing style to adapt to he curve, the glass should be curved too.
« Reply #3 on: December 17, 2018, 04:21:48 pm »
I attach You a starting file. Hope You can use it to further define Your style.
leonardo.afanador
« Reply #4 on: December 17, 2018, 04:59:59 pm »
thank you rookas,
I´m going see your file and try to understand your solution!
best regards,
