Author Topic: Incremental Staircase Tread Width using Spline  (Read 4836 times)
Ryan
« on: April 24, 2018, 09:43:34 am »
Hiya
Does anyone have any tips for creating a staircase that increases in width per stair tread from top to bottom?  Currently, I am using an L1S generator, a standard box segment (which is stepped in the deform tab) and a spline to create the stairs direction and height.  How would I adapt this so the bottom or top tread is width adjustable and the treads between adapt incrementally?
I have looked the Christmas Tree II tutorial for ideas but this uses a segment to dictate the height and not a spline which I am currently using.
I hope this makes some sense.
Re: Incremental Staircase Tread Width using Spline
« Reply #1 on: April 24, 2018, 10:26:26 am »
Hi Ryan,
I created a starting scene with couple parameters.
Let me know if I understood correctly what You want to do, If not exactly- please explain in more detail:
« Last Edit: April 24, 2018, 10:33:57 am by Rokas »
Ryan
« Reply #2 on: April 24, 2018, 01:37:22 pm »
Thanks for replying back.
It was the width of the step I was wanting to change from either the top or bottom and the steps in between would gradually increase or decrease to suit, see attached example of the effect I am trying to achieve and my initial attempt.  The trouble I have is that I do not know how to attach the stair height to the length of the spline.
Regards
« Last Edit: April 24, 2018, 01:52:16 pm by Ryan »
« Reply #3 on: April 24, 2018, 02:07:25 pm »
Oh ok, I am sorry for my mistake and I misunderstood width with depth.
As You have not attached Your setup, I modified mine (see attached file with new parameters)
« Last Edit: April 24, 2018, 02:12:08 pm by Rokas »
Ryan
« Reply #4 on: May 05, 2018, 11:48:49 am »
Thanks for your time on this, its much appreciated.
