Author Topic: Some optimizations  (Read 3680 times)
GF2719
Some optimizations
« on: September 06, 2018, 05:24:16 am »
I'm working with some very heavy geometry in RC, and what's become apparent is that RC re-evaluates when you do anything. Here's a few things that shouldn't trigger one (but do at the moment):
1. Adding a Note. Altering the label doesn't trigger one but toggling Move Content & changing the color does.
2. Adding or editing any node, even when not connected to an output Array.
3. Editing a node connected to a disabled output Array.
I used manual update obviously, but I thought i'd write this anyway.
Re: Some optimizations
« Reply #1 on: September 06, 2018, 08:52:38 am »
Hi, for technical limitations, the Style Editor doesn't handle the nodes as "geometry" items, but everything is stored in a XML which is evaluated and processed by Max.
Because this, most of changes in the Style Editor requires to re-evaluate the nodes graph, and therefore rebuild the RC object.
I will check it's possible to optimize it for 1 (generically, not update when moving nodes), but i'm afraid 2 and 3 cannot be avoided.
