Author Topic: Banking problem  (Read 1445 times)
Ricousto
Banking problem
« on: December 02, 2025, 07:29:05 pm »
Hello
As you can see, I'm trying to do door frame ornaments.
One of these doors is curved.
And this is where the problem arises. I have a banking problem.
I thought it would be simple with Rules->Banking->Modify=0, but it didn't change anything.
How can I avoid this problem ?
I'd like to take this opportunity to ask if there are any resources (tutorials or other)
that would provide good advice for this type of exercise—I'm referring to ornaments
with different decorative elements, creating sequences, etc.
Thank you!
Re: Banking problem
« Reply #1 on: December 03, 2025, 09:25:31 am »
If setting the Override Banking / X Rotation to 0 doesn’t help, I recommend applying the Reset XForm > Reset Selected utility to the base spline, and after that, right-click and choose Convert To > Convert to Editable Spline to see if it resolves the issue.
Ricousto
Re: Banking problem
« Reply #2 on: December 03, 2025, 11:39:08 am »
neither seems to solve the problem  :-\
Re: Banking problem
« Reply #3 on: December 03, 2025, 12:28:17 pm »
In such a case, if possible, please feel free to send us your scene (ideally simplified and containing only the problematic object(s)) so we can check it here. Thanks in advance.
Ricousto
Re: Banking problem
« Reply #4 on: December 03, 2025, 04:57:35 pm »
thank you
sent
Re: Banking problem
« Reply #5 on: December 04, 2025, 11:01:55 am »
Replied by email.
