Author Topic: Basic 1S Array problem/limitation?  (Read 8082 times)
TL1895
« on: January 16, 2024, 04:17:04 pm »
I am wondering if anyone can help me fix my style, please?
It's a basic 1S array with 1 spline and one segment.
It is a roof fascia that works great, except it fails if the roof is sloped at all (And they are all sloped on this project.)
As soon as I raise a vertex in Z axis, the entire RC breaks, twisting the segments all at odd degrees.
Is there a simple way to fix this?  I tried choosing vertical and it almost worked, but it did not fillet the corners.
Using the current release with 3dsMax2019, win10
Thanks in advance,
TL1895
nubo
Re: Basic 1S Array problem/limitation?
« Reply #1 on: January 16, 2024, 04:43:48 pm »
Did you try using RC Spline with banking?
I'm not sure if it will fix all your problems here but it's worth a try.
I'd also try breaking the vertices in places like that and maybe add a unique start/end segment but that would also require some conditional check to have it only on the sloped splines.
Przemek
TL1895
« Reply #2 on: January 16, 2024, 05:06:19 pm »
Thanks for the suggestions! No, I did not yet try RC spline with banking.
TL1895
TL1895
« Reply #3 on: January 16, 2024, 05:10:59 pm »
TL1895
Is this what you are referring to?
If so, changing all the values had no visible effect in the viewport...
« Reply #4 on: January 16, 2024, 06:00:16 pm »
Enabling the Override Banking / X Rotation feature within the Transform Operator placed between the Segment and the Generator should help. In case of any further troubles with it, please feel free to send us / upload your scene and we'll check it here. Thanks in advance.
TL1895
« Reply #5 on: January 16, 2024, 06:57:22 pm »
Thanks Michal,
It did fix the rotation problem, but still doesn't trim...maybe it's not really possible.
I sent the file via wetransfer, in case it could be accomplished,  it would be a huge time saver...
Thanks!
TL1895
TL1895
« Reply #6 on: January 16, 2024, 07:11:42 pm »
In case anyone else wants to try, here is the link...
https://we.tl/t-8pSVmjIyKY
It's a Max2019 file...
TL1895
« Reply #7 on: January 17, 2024, 09:59:14 am »
You can fix it by adding a short horizontal section to your base spline "rc testing edge path". Please find attached the modified scene (240117_rcRoofEdge_iToo.max). I hope that helps.
TL1895
« Reply #8 on: January 17, 2024, 03:45:50 pm »
Thanks Michal,
That was helpful, but it won't quite be the solution as it changes the roofline from the architect's drawing.
I made it temporarily with regular poly modeling/boolean ops...
Thanks again,
TL1895
