Author Topic: Basic Linear 1S2 & Markers - default not filling out correctly  (Read 7826 times)
LC3D
Hi there,
I'm having an issue whereby I'm using markers to insert a driveway section into the road curb, however I cannot get the default curb section to slice correct around the driveway section - see attached image...
I've tried changing the default mode from adaptive, tile, scale etc... added more sections the geometry and nothing seems to work?
in other words it isn't cutting the hole/space for the marker geometry to insert snuggly...
any help would be greatly appreciated.
Thanks.
Re: Basic Linear 1S2 & Markers - default not filling out correctly
« Reply #1 on: July 09, 2024, 10:28:07 am »
We should need the Max file, to see exactly how have you created this RC style.
Anyway, have you tried using spline's material ID to define the driveway section, instead markers ? This is the method we use for our 'Curbs' library.
I would suggest you take a look to it, because it lets you to define each section in a very precise way.
