Author Topic: basic problem with a bookseller  (Read 7394 times)
DC3101
« on: November 25, 2014, 11:58:04 pm »
Hi I am having a problem making a bookseller, I am following the steps of the tutorial to make a bookcase but I have this problem when placing the segment to delete that section. Could someone please help me.
Re: basic problem with a bookseller
« Reply #1 on: November 26, 2014, 11:19:23 am »
It could be the case that Extend to Side is turned on for the Y Evenly segments, in this case the shelves will ignore the padding values of the empty segments used in the Left/Right inputs. This should be Off for this style to work:
If this doesn't work and you're able to upload the style I'd be happy to take a more detailed look.
Many thanks,
Paul.
DC3101
« Reply #2 on: November 26, 2014, 02:55:24 pm »
No ... Im still having the same problem, I attached the file.
« Reply #3 on: November 26, 2014, 03:17:02 pm »
Please see the attached. To make the file work I found it was necessary to turn off Extend to Side for the shelf generator and then add a Left padding value for the empty segment used in the Left and Right inputs.
Many thanks,
DC3101
« Reply #4 on: November 26, 2014, 11:26:30 pm »
Woww...thanksssss
