Author Topic: Railclone 2 bug - file crashes when rendering sequences  (Read 3491 times)
Ben
« on: February 08, 2016, 09:12:41 am »
Hi guys
I seem to have found a bug. It is something that has been an immense pain in the butt for quite a while. But we did not know what caused it.
Basically whenever we rendered a sequence, the file would crash. It would render the first frame and maybe the second frame, but then crash when the next frame starts to render.
I have tracked it down to the source which seems to be railclone, more specifically when railclone is being projected onto a surface.
We build our terrains lately using this technique, because it allows us to make changes to the road or terrain very quickly.
If I put a edit poly modifier on top of the railclone object, the crashes disappear, but this defeats the purpose of using railclone to save up on memory.
I can supply an example if you would like.
I am using Railclone 2.5.0 and Vray 3.3
« Last Edit: February 08, 2016, 09:16:52 am by Ben »
Re: Railclone 2 bug - file crashes when rendering sequences
« Reply #1 on: February 08, 2016, 09:29:40 am »
Hi, this is a known issue, fixed in RC 2.5.2 beta.
Note: the fix works only with V-Ray 3.3 or above. Unfortunately we cannot fix the problem with previous versions.
Ben
« Reply #2 on: February 08, 2016, 09:34:36 am »
Thank you, sorry I only saw the other thread now.
I tested it and it seems to be working now.
