Author Topic: Radial Paving Array?  (Read 3848 times)
cboogie
« on: September 27, 2016, 10:00:12 pm »
Is there a good way to create a radial paving array?  I have a series of arc'd pavement sections that require a specific selection of brick colors.  My first thought was to create a 2D array, but I can't quite figure out how to make the bricks follow the arc of the paved area.  Is this possible in a 2D array?
Re: Radial Paving Array?
« Reply #1 on: September 28, 2016, 11:20:28 am »
The Default Segment : Adaptive mode will be probably the most adequate for this task and the recommendable Geometry : Y Mode would be the Free one. Each Segment will be placed using its local X axis. Attaching a sample scene using this set-up.
Please feel free to check following tightly related thread "circular paving" for more tips. Hope you'll find it useful.
cboogie
« Reply #2 on: October 18, 2016, 09:58:44 pm »
this worked out really well.  I was able to build out a series of 2D arrays that were built from a single arc.  Then in each array I was able to mix the brick colors to match their specification colors using the material snap in.  This would have taken me forever to create in a giant map or to get the arc correct in the standard array tool.  Thanks so much!
