Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Object scale change
« previous
next »
Print
Pages: [
1
Author
Topic: Object scale change (Read 4028 times)
lukx
Full Member
Object scale change
on:
December 14, 2020, 09:29:35 pm »
Is it possible to do this kind of string chair back with railclone.
So the strings are getting shorter closer to the arms?
Logged
www.lukx.com
Hero Member
Re: Object scale change
Reply #1 on:
December 14, 2020, 10:42:06 pm »
Hi.
Have You tried with
this technique
already?
I don't know better way for such structure.
Logged
lukx
Full Member
Reply #2 on:
December 15, 2020, 06:53:03 am »
Thank you Rokas but I can't get the rope to follow the spline(rotating) also top and bottom splines aren't excluded and the scaling of shortest ropes is too flattened.
Logged
www.lukx.com
Hero Member
Reply #3 on:
December 16, 2020, 03:20:08 pm »
Hi again.
This is my attempt at this chair. Splines used should have some obvious direction so RC can make geometry for them. Otherwise- not possible. As a final tweak You can add FFD on top of RC itself.
Hope this helps at least a bit.
Logged
lukx
Full Member
Reply #4 on:
December 16, 2020, 03:36:52 pm »
Thank you Rokas, looks awesome! What do you mean "Splines used should have some obvious direction so RC can make geometry for them" ?
Logged
www.lukx.com
Hero Member
Reply #5 on:
December 16, 2020, 03:42:55 pm »
You could not align rc segment because they are too vertical. I have increased the angle they are sloping.
Logged
lukx
Full Member
Reply #6 on:
December 16, 2020, 03:45:45 pm »
Oh, got it, thanks for this tip.
Logged
www.lukx.com
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Object scale change
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
