Author Topic: Railclone 3.1.9b Bug  (Read 4174 times)
M55
« on: July 02, 2018, 10:13:31 am »
have problems to type 90 or 10 or anything with a 0 in transform/rotation or wherever
if i type in 9 it´s ok but if i type 0 (to get 90) the render to texture window opens
happens to me in 2018 and 2019
after i restored the style editor view it works again
strange
« Last Edit: July 02, 2018, 10:17:48 am by M55 »
Re: Railclone 3.1.9b Bug
« Reply #1 on: July 02, 2018, 01:16:22 pm »
Can't reproduce.
You fixed it too, right.
M55
« Reply #2 on: July 02, 2018, 02:13:34 pm »
yes i fixed it
the style editor was somehow screwed up ... very strange
i did "restore default layout" and it works fine again
« Reply #3 on: July 02, 2018, 04:05:08 pm »
This would happen because by default Max "captures" the keyboard for their shortcuts (i.e. '0' for the Render to Texture dialog).
When the interface enters in certain controls (as a numeric edit box), it's necessary to release the keyboard from Max, and capture it from the control (and back when the focus changes).
The Style Editor does the same, capturing and releasing the kebyboard when needed.
But Probably some Max event is recapturing the keyboard while the editor is open, causing this issue.
At least we can reproduce the same steps, it's difficult to fix it.
Anyway, this should happen only ocasionally, and the workaround is simple: just close and open the Style Editor.
