Author Topic: Material operator and difference between viewport / render windows  (Read 3334 times)
Cherami
I've created a tiles with railclone, closely similar to the tutorial "Macros: Mirror Variations and Stepped Rotation".
I have some difference between viewport and render (see attached files). It seems that material operator doesn't work when i'm rendering a frame.
What i'm missing to have the same result between viewport and render window?
I'm using Corona renderer and 3DSMax 2018
Regards,
Re: Material operator and difference between viewport / render windows
« Reply #1 on: October 07, 2019, 04:25:18 pm »
Currently, when using the Corona Renderer, the Use Instancing Engine option should be disabled, because Material / UVW XForm Operators are just partially supported (as you can see in the Feature Compatibility table) - to get these working correctly with the Corona Renderer, the Use Instancing Engine should be switched off.
Cherami
« Reply #2 on: October 07, 2019, 04:36:39 pm »
Thanks. It works well with Use Instancing Engine option disabled.
