Author Topic: Blending between two Material ID's on spline  (Read 4706 times)
Keith678
« on: April 24, 2023, 11:17:12 am »
Can anyone tell me how to create a blend between these two linear 1S arrays. At the moment it creates a gap between the two.
Is it more to do with the spline itself or the arrays?
Thanks.
« Last Edit: April 24, 2023, 11:24:58 am by Keith678 »
Re: Blending between two Material ID's on spline
« Reply #1 on: April 25, 2023, 12:12:26 pm »
Using the Conditional Operator to choose the corresponding Segment based on the Material ID instead of two Generators will do the trick. Please feel free to check this related thread.  I hope that helps.
« Last Edit: April 25, 2023, 12:15:24 pm by Michal Karmazín »
Keith678
« Reply #2 on: April 25, 2023, 02:06:32 pm »
Excellent, works very well.
Now I only need to fix it so the end piece ends at material ID 1 rather than 2.
Any ideas?
« Reply #3 on: April 26, 2023, 09:38:17 am »
I’m glad to hear, that it helped. You can use a very similar approach – adding another Conditional Operator – in this one checking the Position on Section.
Keith678
« Reply #4 on: April 26, 2023, 10:09:39 am »
Thanks for all this.
I still can't make it work. I'm sure I'm just dong something silly.
« Reply #5 on: April 26, 2023, 10:18:30 am »
This Conditional Operator should be wired also to the Default Input – it should be “chained” to the other one. Using the Position on Section - Greater 90% value should work.
Keith678
« Reply #6 on: April 26, 2023, 10:44:14 am »
Hi I've attached the scene. I'm struggling here.
Arslan
« Reply #7 on: April 26, 2023, 01:12:32 pm »
with the laziest approach :)
1.generator > limits > material ID 1
2.generator > limits > material ID 2
Keith678
« Reply #8 on: April 26, 2023, 01:34:02 pm »
Hi Arslan,
Thanks for that. That's what I had in my first post. But this doesn't work on blending the two.
see attached image.
It seems the major issue is when i set the vertex to corner so I guess if I keep it as smooth it will work.
Maybe I'll just keep with what I have so.
Keith678
« Reply #9 on: April 26, 2023, 01:39:40 pm »
Also an issue where you change some heights
Arslan
« Reply #10 on: April 26, 2023, 02:05:19 pm »
Seems like a banking issue. Adding 'transform operator' and enabling 'override banking' option should solve the problem.
Keith678
« Reply #11 on: April 26, 2023, 02:42:20 pm »
Arslan you're a genius!
Thanks for this simple solution.
