Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
BUG - Bottom Padding error - display limit exceeded
« previous
next »
Print
Pages: [
1
Author
Topic: BUG - Bottom Padding error - display limit exceeded (Read 3787 times)
JK1258
Newbie
on:
April 08, 2022, 03:10:20 pm »
In a very simple 2s1 railclone i cant set top or bottom padding higher than 19.
If you set it to 20 i get "display -limit exceeded".
Max 2021, rc 5.1.2.
Mike
Logged
Hero Member
Re: BUG - Bottom Padding error - display limit exceeded
Reply #1 on:
April 08, 2022, 08:18:33 pm »
I can`t open the file due to the MAX version, but you can increase limits in the Display rollout.
If you still have issues try to turn off Slicing.
Last Edit: April 09, 2022, 10:00:28 am by Dragan
Logged
JK1258
Newbie
Reply #2 on:
April 08, 2022, 08:45:26 pm »
Display limit is 5000 segments and 10 mil poly. This generator stops building at like belowe 1k segments and 10k polys . It's a bug.
i have attached max 2018 version.
Logged
Hero Member
Reply #3 on:
April 08, 2022, 08:55:39 pm »
Thank you for the file.
Switch your Spline from Curve to Line. That should do the trick.
Logged
JK1258
Newbie
Reply #4 on:
April 08, 2022, 08:59:16 pm »
Thanks for your answer,
It does not work.
I also tried to change adaptivness in spline and interpolation od that spline i RC.
Also point clous display displays the whole mesh, but it does not render.
miek
Last Edit: April 08, 2022, 09:04:21 pm by JK1258
Logged
Hero Member
Reply #5 on:
April 08, 2022, 09:23:47 pm »
Hm, works fine here.
Please check the file.
Logged
JK1258
Newbie
Reply #6 on:
April 11, 2022, 02:02:26 pm »
Your file from max 2018 works.
Mine made in 2021 does not. If i uncheck "slice" in the segment options it works.
But still if i make a 2s1 RC object in max 2021 it does not work with very little polygons to chop up.
I still think that this is a bug, because it makes 2s1 unusable for me
Logged
ITOOSOFT
Hero Member
Reply #7 on:
April 11, 2022, 04:43:39 pm »
Thanks for the scene File. There is something amiss here that appears to be related to the combination of fixed size and padding used. I'm passing it to our development team for further investigation
Logged
JK1258
Newbie
Reply #8 on:
April 11, 2022, 04:53:56 pm »
Thank you for poiting that those two collide. I will just controll the size outside the RC.
mike
Logged
Administrator
Hero Member
Reply #9 on:
April 12, 2022, 10:57:59 am »
Fixed for next update.
Logged
JK1258
Newbie
Reply #10 on:
April 12, 2022, 03:38:10 pm »
Nice!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
