Author Topic: Request: button to select spline in Base Objects menu  (Read 2435 times)
Grainger
« on: April 12, 2021, 11:27:55 am »
I would love te have a "select spline" button in the Base Object menu. Often it is easy to select the RailClone object in the viewport, but to even see the spline in the viewport, let alone te select it is a pain! And yes, I could select the spline in the scene or layer explorer, but doing it in the viewport works better and faster for me!
Are there more people want to see this?
Re: Request: button to select spline in Base Objects menu
« Reply #1 on: April 12, 2021, 11:34:37 am »
With a RailClone object selected, Right click in the viewport and click Select RailClone Base Object. If a style only uses a single base object it will automatically be selected. If it uses multiple base objects, a dialog will open allowing you to choose the one to select.
Grainger
« Reply #2 on: April 12, 2021, 11:48:51 am »
I've never known that, but that's even better/faster!
Thank you!  :)
