Author Topic: box mapping is not working  (Read 5828 times)
KarloBalboa
« on: February 15, 2018, 10:34:26 am »
Why doesn't Railclone box mapping works in my all scenes? If I straight forward open sample max file - box mapping simple works. But if I want to the same sample max file to import into my scene - it does't work. How can i get it to work into my scene? I want to avoid a miserable workaround: migrate all my scene into sample max file. Thanks.
Railclone 3.0.9
« Last Edit: February 15, 2018, 10:39:05 am by KarloBalboa »
Re: box mapping is not working
« Reply #1 on: February 15, 2018, 11:32:14 am »
To get the Apply Box Mapping feature working correctly with the Corona Renderer, the Use Instancing Engine should be switched off as shown on the attached screen-shot.
Let me add, that some features are "fully supported" only in case of the V-Ray render engine (as you can see in the Feature Compatibility table, for the rest of renderers it can be enabled by turning off the instancing engine). Use of features like Material / UVW XForm Operators are just partially supported.
