Author Topic: Vray Displacement not inherited to RailClone  (Read 3598 times)
winoo1
« on: July 31, 2021, 01:27:17 pm »
Hello !
I'm working on a project and i've faced a problem . I'm creating building facade with perforation. Originally source object has vraydisplacement modifier with water level to achieve holes, but it seems, that railclone doesn't inherit this Vraydisplacement modifier. Am i doing something wrong or there is a limitation in railclone?
Best regards
Bartek
Re: Vray Displacement not inherited to RailClone
« Reply #1 on: July 31, 2021, 01:44:57 pm »
Try to uncheck "use instancing engine" under Display>>Render
If that does not help try to copy/paste the Vraydiplacement modifier on the top of the RailClone in the modifier list.
« Last Edit: July 31, 2021, 02:17:07 pm by Dragan »
winoo1
« Reply #2 on: July 31, 2021, 01:49:11 pm »
Thank you, i will test it out! :)
EDIT:  It worked :) Thank you very much :)
« Last Edit: August 01, 2021, 01:42:42 pm by winoo1 »
