Author Topic: Brick bond pattern after marker  (Read 3467 times)
arch3d
    • arch3d.pl
« on: December 09, 2020, 05:54:43 am »
I got such situation:
after placing marker my brick bond pattern doesn't work correct. Any ideas?
Here is link to scene. I dont know i cant uplad data on board
https://we.tl/t-2MpjkeLMFv
Thanks for help
Re: Brick bond pattern after marker
« Reply #1 on: December 09, 2020, 06:40:34 am »
I can't open the file due to Max version but as I can see from the picture I guess you are doing A2S and making space with Null on Marker position.
If you shift blocks with "Start/End Sequence"  of full/half size then try this trick:
Make Compose (Sequence mode) with Null Segment & "Start/End Sequence" and connect this to the Marker Connector.
« Reply #2 on: December 09, 2020, 08:12:21 am »
Just Checked Dragans solution. Seems to work as described:) You need no max ;)
P.S. File attachments are fixed now.
« Reply #3 on: December 09, 2020, 08:35:29 am »
Great! Thank you Rokas.
I had a similar situation a few weeks ago  ;)
arch3d
    • arch3d.pl
« Reply #4 on: December 09, 2020, 12:06:36 pm »
Thans for saving couple days of work. I wasn't even close to find solution.
Love you:)
arch3d
    • arch3d.pl
« Reply #5 on: December 11, 2020, 04:28:19 am »
its even better if i put empty segment instead of larger brick. It can avoid problem with opening near corner.
Thanks again
