Author Topic: Brick pattern for facade cladding  (Read 19526 times)
ShaneMcG
« on: November 13, 2024, 07:02:09 pm »
Hey there,
I want to create a facade cladding made out of tilted, slightly overlapping large wooden panels (200x40cm), that have a classic "brick pattern" to them. With the cladding macro I either get a straight or a totally random pattern of the cladding panels. Is there a way to achieve the brick pattern for the panels with the cladding macro?
Thanks in advance!
Re: Brick pattern for facade cladding
« Reply #1 on: November 14, 2024, 08:38:03 am »
You can easily adapt the Cladding macro to use the Conditional Operator to select a 'half' segment as the first segment on each odd row, creating the desired pattern. Please see the attached sample scene (241114_RunningBondCladding_ITOOSOFT.max).
ShaneMcG
« Reply #2 on: November 14, 2024, 09:40:52 pm »
Hey Michal,
just saw your answer, downloaded the file and tried it out - it works like charm, thank you very much!
Once again the Itoosoft forum has been so helpful - wonderful work, guys!
