Author Topic: Brick wall with layer offset  (Read 2492 times)
iCreateLtd
« on: June 01, 2022, 10:30:06 am »
Hi all.
I need to create a series of brick walls for a holiday park that steps in 2.5cm on each new level.
I've found a video on Youtube showing how to make a brick wall but it's the stepped bit I'm not sure about
Any help would be great.
Re: Brick wall with layer offset
« Reply #1 on: June 01, 2022, 03:05:53 pm »
Thanks for the question - that's harder than it looks!
Please see the attached file to see if it helps solve this case.
Best wishes,
iCreateLtd
« Reply #2 on: June 01, 2022, 04:12:31 pm »
You are amazing!!
That seems to work perfectly.  It also works on a closed rectangle which will also be needed.
Many thanks
« Reply #3 on: June 01, 2022, 04:29:52 pm »
Great! Glad to hear that it helps.
Best,
