Author Topic: Railclone Segment Material on XReferenced Assets  (Read 2634 times)
Lars Egerrup / LKE Design
    • LKE design website
« on: January 05, 2023, 03:07:28 pm »
Is it true that RailClone can't use Segement Materials when using objects imported as Xref Objects?
The models work fine in it self, - all materials are visible - but when used inside RC, they are omitted.
Lars Egerrup
LKE Design
E: Lars@LKEdesign.dk
W: www.LKEdesign.dk
Re: Railclone Segment Material on XReferenced Assets
« Reply #1 on: January 05, 2023, 08:14:33 pm »
Check if the Use Instancing Engine is set to on.
« Reply #2 on: January 07, 2023, 08:43:36 am »
That's it. 'Use Segment Material' should work with XRefs (at least it works in our tests), but this feature is only available with the instancing engine.
When instancing is not used, RailClone works as a standard mesh, limited to a single material (as other Max objects).
If it doesn't work, please tell us your render engine.
