Author Topic: Expressions?  (Read 10568 times)
Macker
Expressions?
« on: June 14, 2016, 10:53:11 am »
Hey guys, I've seen in a lot of the styles and tutorials that expressions are used to make certain things happen, but not being from a coding/mathematics background I look at them and genuinely have no idea what's going on. I have no idea whether it's written in a certain type of code (maxscript?) or what the syntax is, or what things I can control with it, etc.
Are there any tutorials around to help with this? I'm sure I can't be the only one.
Re: Expressions?
« Reply #1 on: June 14, 2016, 04:55:09 pm »
Hi. No, it's not Maxscript. We actually use the same engine for Expression Controllers in Max. You can find a reference here. In next updates we have plans to replace it for our own language, used actually for Forest Effects.
There is not a specific tutorial for expressions, but you can find several resources there:
- RailClone guide->Parameters and attributes->Exercise: Exporting Attributes and simple maths with the Arithmetic operator.
- RailClone guide->Creating Conditional Relationships->Exercise: Creating conditions using the Selector operator and expressions.
The full list of functions and properties is available from the Expressions Editor.
I hope that helps, if you need more specific help, please don't hesitate to ask.
viktaZ
Re: Expressions?
« Reply #2 on: June 05, 2018, 12:43:06 pm »
Hi there,
now, I am not new to programming and i've just started to use expressions, more like tried, really: what I've noticed is that my version of railclone doesn't really accept anything as an expression.
Example 1:
"Next Steps with Railclone" chapter 3 - Parameters and Attributes -> Exercise: Using Expressions, the floor tile model
Typing in the expression shown in the tutorial doesn't work, not even by copy-pasting the code in the expression, it returns a parse error. See "railclone_expression_parse_error.jpg" attached.
Example 2:
Since I could not get the expression work in example 1, I wanted to see if your parametric bridge tutorial works, shown here:  https://www.itoosoft.com/tutorials/bridge1
Replicating the same structure and input to Railclone as instructed in the tutorial returns the same parse error. See "railclone_expression_bridge.jpg" attached.
Neither did I have any luck trying to come up with simple expressions like "Input1+Input1", input 1 being a constant, with a value of 2. See attached "simple_expression.jpg"
I am using 3dsMax 2017 and Railclone Pro 3.1.0
I did notice that the expressions UI has changed since either of the tutorials above, maybe the syntax did too?
What am I doing wrong?
Re: Expressions?
« Reply #3 on: June 05, 2018, 01:03:59 pm »
Hi viktaZ,
Thank You for spotting this! This guide was done for RailClone v2. We should update this part.
Since RailClone 3 we have more powerful expression editor, though it requires a little modifications from v2.
expression "-1*(Input/4)" in v2 should be written in v3 like this:
return -1*(Input/4);
You should add "return" in start of "expression" and end it with ";"
viktaZ
Re: Expressions?
« Reply #4 on: June 05, 2018, 01:52:52 pm »
Hi Rokas,
Thanks a lot, unsurprisingly, my expressions work now!
Another question is whether the iToo team would consider a full tutorial on expressions? It would be nice to have a complete written manual at least.
Just off the top of my head I have a few new questions:
- I assume that "return" is some kind of special function that outputs the expression, since it has to be named in the expression. What other "special" functions are there like "return"?
- As a semicolon has to be used, is it possible to give multiple expressions at the same time?
I understand that the expressions and functions do have their descriptions, but that doesn't help much with learning the syntax for example.
Anyway, thanks again!
Re: Expressions?
« Reply #5 on: June 08, 2018, 01:50:35 pm »
Full tutorial? No plans in near future but feel free to ask questions.
We have some documentation here.
special functions like "return" ?
"Print" this prints output to evaluator instead of outputting it through the wire.
; ? Yes multiple expressions all the way!
example:
Code: [Select]
#declare vars:
real a =e; #e=2.71...
int b =2;
real In = Input1;
#compute:
real c= a*b*In;
print c;
return c;
