Author Topic: Bricks  (Read 3292 times)
Sergey_Dobrij
Bricks
« on: September 09, 2020, 09:55:43 pm »
Hi everyone! When I shift along the x axis, by the size of the brick. I'm missing the whole object. For example... brick size 250 mm, if I put 249, then everything works
And please tell me, how can I avoid this problem?
« Last Edit: September 09, 2020, 10:21:50 pm by MF3751 »
Re: Bricks
« Reply #1 on: September 10, 2020, 07:59:52 am »
Would you please attach Your style. We need to see the style to comment on it.
Thanks.
Sergey_Dobrij
Re: Bricks
« Reply #2 on: September 10, 2020, 09:35:14 am »
Good afternoon! I'm attaching a scene. Thank you!
Re: Bricks
« Reply #3 on: September 10, 2020, 09:49:49 am »
You are adjusting padding. if You make it bigger than segment- it disappears thus messing up all style.
It is better to transform translation in this case.
Set Sequence to work on Y increments
clear all padding values.
Adjust Fixed Translation on X.
Hope this helps
Sergey_Dobrij
Re: Bricks
« Reply #4 on: September 10, 2020, 09:52:04 am »
Thank you bro!)
Sergey_Dobrij
Re: Bricks
« Reply #5 on: September 10, 2020, 09:57:55 am »
Hope this helps
Tell me, can I make the left side like the right? Thank you!
Re: Bricks
« Reply #6 on: September 10, 2020, 10:17:23 am »
Sure, You should start every other Y row with a half size brick.
Sergey_Dobrij
Re: Bricks
« Reply #7 on: September 10, 2020, 10:20:23 am »
Thank you for wasting your time on my stupid questions! All the best
