Author Topic: Composed Blocks not aligning in adaptive  (Read 3348 times)
Alex.S
« on: September 11, 2020, 10:29:10 am »
Here is a simple test case of 3 long boxes, instanced from the same base mesh with vertical translations. I combine them (grouped) and reset the pivots, and all kinds of strange things occur...
It should be 3 boxes with a 5cm vertical gap between them forming a continuous wall. Not too sure what I am doing wrong here, maybe i need to be nesting linear generators instead?
Re: Composed Blocks not aligning in adaptive
« Reply #1 on: September 11, 2020, 10:36:37 am »
Hi. You are using random translation. from 0 to 0.3 instead of fixed, thus this behavior:
Alex.S
« Reply #2 on: September 11, 2020, 03:30:46 pm »
sorry ugh :o
Alex.S
« Reply #3 on: September 11, 2020, 03:34:35 pm »
Ok, the segments still overlap though...?
This only occurs with vertical deform settings. On adaptive they work ok.
« Reply #4 on: September 11, 2020, 05:47:52 pm »
If segment deforms is vertical, try disabling `Slope Fixing`
Alex.S
« Reply #5 on: September 14, 2020, 11:40:41 am »
Ah, thanks yeah that was the issue...
