Author Topic: Vray Decals  (Read 3826 times)
VelvetElvis
Vray Decals
« on: March 25, 2022, 05:08:13 pm »
Does the latest build for rail clone support vray decals? I'm on a bit older of a version and it currently does not. I'm using decals to add puddles to the street and it works on all objects except my rail cloned curb.
Re: Vray Decals
« Reply #1 on: March 28, 2022, 09:37:54 am »
Thanks for the question. I've just done a basic test here and it all appears to be working as expected.
I hope that helps,
VelvetElvis
Re: Vray Decals
« Reply #2 on: March 29, 2022, 03:29:30 pm »
Thanks for the response! That means that it's probably our older version that lacks support. I'll get with out IT dept to push out the new update.
Simi23
Re: Vray Decals
« Reply #3 on: April 25, 2022, 08:16:44 pm »
My question about V-Ray Decals is if there will be a support to use the decal to do some scatter.
Sometimes it is difficult to have accurate results where some displacement is on the surface. It would be helpful in my projects to do "skip stripe" markings on-road using a decal. And scatter V-Ray Decal object would work well.
So my question is, is there planned support for this object?
Re: Vray Decals
« Reply #4 on: April 26, 2022, 10:06:52 am »
I'm afraid that one is a limitation that only Chaos can resolve. We use the same underlying techniques as V-Ray Instancer so if something doesn't work with Instancer it won't work with Forest Pack or RailClone either. If it doesn't work with Instancer, it also means we can't work around it without Chaos' help.
One workaround that will help is to instantiate it with RailClone tools.
I hope that makes sense
« Last Edit: April 26, 2022, 10:10:26 am by Paul Roberts »
