Author Topic: Endless stream of zeroes and ones  (Read 5962 times)
Ingo
« on: December 27, 2017, 06:23:39 pm »
Hi there,
I like to animate an endless binary stream of randomized zeroes and ones. I built a simple Railclone with 2 Segments (0 and 1) and a Randomize. When I animate the translation in the transform tab of the segment, Railclone won`t produce new numbers.
Any tips how I can animate the stream differently?
Thanks in advance
Ingo
Re: Endless stream of zeroes and ones
« Reply #1 on: December 28, 2017, 11:37:42 am »
Hi Ingo,
I'm not sure, how the animation should look like, but what about making the base spline larger, animate it and restrict the desired part by a Clipping Area? Attaching a sample scene. Hope you'll find it helpful.
Ingo
« Reply #2 on: December 28, 2017, 01:22:08 pm »
Hi Michal,
thanks for the tip, but unfortunately, the spline has to be animated a differnet way to fit my projekt. I have to animate the verticles of the spline, so that the form and lenght will chance over time.  So I can´t animate the movement of the spline.
« Reply #3 on: December 29, 2017, 12:38:47 pm »
Hi Ingo,
While using the advised "Clipping Area work-flow", the movement can be archived also by animating for example Generator's Limits > Padding > Start / End value(s), but most probably that'll not fit your scenario neither. Please feel free to describe more in detail your scene set-up (ideally upload a simplified scene). Thanks in advance.
