Author Topic: Plant bed - conform to surface without gaps  (Read 2486 times)
UR1283
« on: May 10, 2021, 07:03:08 pm »
I am creating some plant beds based on the plant bed tutorial and I need it to conform to the slope that my building is on. My issue is that when I have it linked using Surface it causes the corners to separate. How can I ensure the vertices stay aligned and don't create gaps?
Re: Plant bed - conform to surface without gaps
« Reply #1 on: May 10, 2021, 08:22:19 pm »
Can you please downgrade the Max File at least to Max2020?
UR1283
« Reply #2 on: May 10, 2021, 09:25:53 pm »
Here it is saved for 2018.
« Reply #3 on: May 10, 2021, 10:44:19 pm »
Not an easy fix.
Vertex Weld could help but not in extreme situations.
UR1283
« Reply #4 on: May 11, 2021, 04:59:08 pm »
Thanks for looking into this. It welds a few verts but then faces start disappearing? seems to work a bit better if I switch the mode to tiling (instead of adaptive) This is a limitation I am guessing? I will probably have to just built them all manually, or just the ones with errors that are visible to the camera.
