Author Topic: Wall on uneven terrain  (Read 5920 times)
Geoff K
« on: June 27, 2017, 10:18:56 pm »
I am trying to create a palace wall on a hilly surface, but I am running into problems where the wall has sharp angles.
See this video, and notice how the corners separate.
Is there any way around this?
I keep thinking it would be nice if RailClone could work with splines and generate behavior like Max's Bevel Profile modifier.
Thanks!
   - Geoff
« Last Edit: June 27, 2017, 10:26:29 pm by UJ8701 »
Re: Wall on uneven terrain
« Reply #1 on: June 30, 2017, 05:02:33 pm »
Hi Geoff,
Unfortunate, it's more tricky than it seems at first sight. For example the mentioned Bevel Profile modifier rotates it. If you want it to behave in a similar way, you should use the Deform - Adaptive mode for such Segment.
As mentioned in this tightly related post: "... this is a limitation of this kind of joinery, it wouldn't be possible to create this joint with a simple mitre in real life. This kind of joint would only really work with handrail with a circular cross-section or other profiles where there is no need for a particular face to stay pointing upwards."
Best regadrs,
