Author Topic: Bug report  (Read 4364 times)
JK1258
Bug report
« on: June 05, 2018, 01:53:07 pm »
Max 2016, railclone up to date. With not so straight segment with a tilt and a curved spline i get a weird glitch.
If i move up and down a base line in attached file, the middle segment gets glitchy in upper part. It gets noisy.
But if i move the line with the railclone objects it is all fine.
« Last Edit: June 05, 2018, 02:08:38 pm by JK1258 »
Re: Bug report
« Reply #1 on: June 05, 2018, 02:48:06 pm »
Thank You. We will investigate what causes it and what can be done to fix it.
Re: Bug report
« Reply #2 on: June 05, 2018, 04:24:49 pm »
This is probably caused by limitation of the algorithm used.
I would suggest You change approach to this style.
Use shorter segment and tile it- RailClone is good at that.
Attaching modified scene.
JK1258
Re: Bug report
« Reply #3 on: June 05, 2018, 04:30:23 pm »
I need to use is this way to maintain perfect mapping to make shingles requested by my client.
I can work with it. It is not a problem for me but i thought that you should se any type of unusual behavior of my favorite plugins.
Thank you for a quick reaction!
Re: Bug report
« Reply #4 on: June 05, 2018, 04:39:31 pm »
Indeed, we do appreciate Your feedback, thank You very much. Also, I would like to see Your finished render as well.
