Author Topic: Road  (Read 6055 times)
yossivida
Road
« on: January 09, 2016, 02:08:48 pm »
Hello :)
what is the best way to create a Road with additional lanes connected , i attached a screenshots to explain it better ...
thank you!
Re: Road
« Reply #1 on: January 10, 2016, 12:32:51 pm »
I'm afraid at present RailClone doesn't support joints or intersections. Usually this geometry problem it's difficult to solve even manually, because it requires booleans or other advanced operations. Typically for roads with complex layouts I'll create them simply by meshing closed splines, and then use the same spline to apply Curbs using RailClone.
Many thanks,
« Last Edit: January 13, 2016, 11:16:01 am by Paul Roberts »
Macker
Re: Road
« Reply #2 on: January 13, 2016, 11:09:26 am »
I do the same, roads are a bit of a nightmare but can look good when UV unwrapped and textured that way.
Klonsemann
Re: Road
« Reply #3 on: January 27, 2016, 02:44:36 pm »
i ran into the same problem and found a nice working solution.
Simply build only a half of the road instead of both sides.
Now u can nicely go around corners. For ur curbs, just let the spline run strait through and seperate via Spline ID simular to lower walkways.
With this solution u only have to close the inner holes. Thats simply done with spline+extude.
« Last Edit: January 29, 2016, 12:18:07 pm by Klonsemann »
