Author Topic: Curb Problem  (Read 2479 times)
PC9708
Curb Problem
« on: December 18, 2021, 01:30:27 pm »
Hello There,
I have a problem that occurred after updating to the latest version of RailClone ( 5.0.6 )
Drop curb is now overlapping with the regular curb. I am not sure where the problem is. In the older version, this worked as it should, but now, it doesn't.
I have tried to mess around with the adjustments, but whatever I do, it breaks an array even more.
 Anyone got a suggestion?
Re: Curb Problem
« Reply #1 on: December 20, 2021, 10:40:41 am »
Thanks for reporting this issue, with your help we've been able to identify a bug caused by changes to the limit by material ID feature in RailClone 5. We're working to fix it and will update soon.
Many thanks,
PC9708
Re: Curb Problem
« Reply #2 on: December 20, 2021, 11:59:12 am »
Hi Paul,
Thank you so much for the reply, and for working on the issue. :)
Keep up the good work.
Mario
FC1888
Re: Curb Problem
« Reply #3 on: December 23, 2021, 03:40:10 pm »
Sort of workaround, is to separate the dropped curb section of the spline and create Railclone objects for each (normal and dropped sections) NOTE: bit of a pain on corners though
