Author Topic: Curve parameters  (Read 3535 times)
Sergey_Dobrij
Curve parameters
« on: October 19, 2021, 12:47:07 pm »
Hello! In the future, was it planned to make a parameter of the curve?
Re: Curve parameters
« Reply #1 on: October 19, 2021, 01:15:01 pm »
Hi. No, it's not planned.
What do you want to achieve exactly ?
Sergey_Dobrij
« Reply #2 on: October 19, 2021, 01:28:58 pm »
Hi, I am trying to create a curvature parameter. I thought if there is such a parameter, it can be used as a multiplier of some effect.
Sergey_Dobrij
« Reply #3 on: October 19, 2021, 01:40:58 pm »
Hi!
Another problem I ran into! My geometry is deformed
Sergey_Dobrij
« Reply #4 on: October 19, 2021, 01:48:15 pm »
I think the more correct solution here would be to build in this way. If I'm wrong, please correct me!
« Reply #5 on: October 20, 2021, 08:39:37 am »
That's it. You must use a Y spline to define the curve along the array.
Regarding the deformation, turn off Segment->Deform->Bend and Slice checkboxes.
In RC5 (still in beta), you also can turn on Force Instance, which has the same effect.
Sergey_Dobrij
« Reply #6 on: October 20, 2021, 10:12:00 am »
Thanks! I figured out how to create an array more flexibly. I will definitely update to version 5 a little later!
