Author Topic: offset  (Read 11024 times)
innae1121
offset
« on: June 14, 2025, 06:16:02 am »
I'm connecting the building's Z-offset value via the Array 2S Generator.
The Spline Offset Modifier works normally in all situations.
When using the Spline Offset Operator, the height becomes random.
This issue occurs when using multiple attached splines to generate buildings simultaneously; it works correctly with a single spline.
I'm wondering if I need to connect other additional operators to the Spline Offset Operator for the settings to work correctly.
Re: offset
« Reply #1 on: June 16, 2025, 09:51:45 am »
Are these "sub-splines" already handled within a single Editable Spline object, or are you attaching them using the Spline Basic Operator in the Combine mode? If possible, would you mind sending us a simple scene where the mentioned behavior can be reproduced? Thanks in advance.
