Author Topic: Calculate UVW Coordinates - get X Mapping Size from Spline length  (Read 4632 times)
suppenhuhn
Hi!
I'm using one railclone object using two Array2S Generators to create two window variations ( high and small ). The heights are parametric inputs and are assigned via Spline Mat-IDs ( 1=high, 2 =small ). So far so good.
Now i'm trying to create a third object -> a simple Array2S Generator with only a default plane, which should work as a "backgroundplate" for each window. And each plate should have a UVW Mapping Size matching to it's width and height:
  • The UVW Y Mapping Size is easy -> i'm using the parametric input for the window heights as it's value.
  • But i'm lost trying to get the X Mapping Size -> this size should be the length of every single spline used in the base object
Is there a way to get the length of each spline used in the base object path ? Guess that expressions could solve it - found X Spline Length, X SplineSection Length, X Spline MatID etc. but no glue how to use em
Hope you'll understand what i'm trying to say  8)
« Last Edit: March 21, 2020, 02:52:38 pm by suppenhuhn »
suppenhuhn
Re: Calculate UVW Coordinates - get X Mapping Size from Spline length
« Reply #1 on: March 22, 2020, 04:32:46 pm »
I've tried with expressions but i can't get running  :-\
When plug this arithmetic expression into the X Mapping Size then the UVW Mapping isn't correct...hmmm
P.S. Is there a way to check what value a expression is returning - just like  log, echo or print commands in other programming languages?
« Last Edit: March 22, 2020, 04:49:43 pm by suppenhuhn »
« Reply #2 on: March 23, 2020, 10:05:46 am »
I am attaching my solution to the described issue.
To understand what expressions are returning, sometimes helps to create new helper generator with segments variable Z size for example. There are no text output evaluation.
Hope this helps.
suppenhuhn
« Reply #3 on: March 23, 2020, 11:34:11 am »
Awesome - works perfect. Thank you! A real "pro-approach" with no need to mess with UVs !! :-)
But one question: I'm using spline vertecies to create X Evenly window-elements. When adding a vertex into spline ID 2 - railclone will create 2 "background segments".
Is there a way to check if a spline has more segments and ignore them ? My segments always have the same ID, i don't mix IDs within the spline.
« Last Edit: March 23, 2020, 11:42:31 am by suppenhuhn »
« Reply #4 on: March 23, 2020, 12:12:51 pm »
Then set Background generator Bevel Mode to None:
suppenhuhn
« Reply #5 on: March 23, 2020, 12:54:44 pm »
Thank you so much !  8)
