Author Topic: Set evenly count via expression (matID or length of segment)  (Read 4907 times)
HP3623
I want so dynamically set the evenly count on a linear generator. First I tried to set the count via expression using "XSectionLength" as the condition, that didn't work. I then tried to set it via "XSplineMatID" but that is also only returning one value, regardless of what material id I set. Can someone tell me what could be the mistake?
Re: Set evenly count via expression (matID or length of segment)
« Reply #1 on: July 22, 2016, 10:52:11 am »
Unfortunately it isn't currently supported to set the evenly count mode using an expression in a way that would return a different value for each spline. It is possible however using a technique which we originally posted before Count mode was introduced.  You can read about it and download some sample scenes from here. http://forum.itoosoft.com/index.php?topic=2385.msg9030#msg9030
Another option might be to add the segments to the Corner input instead of the Eveny, and divide the spline to add vertices that place the objects.
Many Thanks,
eqko
« Reply #2 on: October 16, 2017, 02:03:43 pm »
don't want to make a new thread, so checking in in this one to see if it's possible yet to
have an evenly count set by XSectionLength
nubo
« Reply #3 on: March 20, 2020, 02:36:41 pm »
Still not available in 2020?  :-\
Are you planning to introduce this feature (wiring an expression to Evenly/Default Count Input) in the future?
Maybe it'd be easier to create some Macro which would emulate that kind of behavior?
Best regards
« Last Edit: March 20, 2020, 02:39:11 pm by nubo »
nubo
« Reply #4 on: March 20, 2020, 04:19:38 pm »
I've made a workaround (attached) but it's far from perfect.
