Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Problematic corner
« previous
next »
Print
Pages: [
1
Author
Topic: Problematic corner (Read 9048 times)
Paulo R. Beck
Newbie
Problematic corner
on:
May 20, 2014, 02:05:01 am »
Hello
I'm trying to make this corner of this building, but I'm not getting ...
What am I doing wrong?
Logged
ITOOSOFT
Hero Member
Re: Problematic corner
Reply #1 on:
May 20, 2014, 09:34:46 am »
Hi Paulo,
I've attached a file with a version of the building style you are creating. I've made a following changes to get the corners to work.
Removed the sequence modifier and used the blank wall only in the default input. Then add the windowed wall to the evenly input, the spacing for this can be adjusted using the generator > Rules > Evenly distance value. Using evenly instead of sequence should prevent windows getting clipped on the corners
Since your corner segments are the same as your default segments you could remove the corner completely, the default section will mitre correctly in the corners (the same is true of the start and end sections). If the corner sections need to be different however then scaling them on the X axis gives them adequate length to correctly bend around the corners.
Set the mode to scale, not necessary but means that default segments will always scale between evenly segments which can produce fewer segments in certain circumstances.
I hope that helps, if you have any further questions please let me know.
Kind regards,
Last Edit: May 20, 2014, 09:37:23 am by Paul Roberts
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Problematic corner
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
