Author Topic: Can railclone use a named reference line to generate?  (Read 6161 times)
BK8837
« on: April 11, 2024, 05:07:18 am »
Hello Itoo Dev Team,
Is there a way a Railclone graph can find a name of specific line and adopt as spline to generate. Is there a script for this?
Example: If merge a Railclone to my scene can the RC  find "Line001" and use that as the generator?
Thank you!
Re: Can railclone use a named reference line to generate?
« Reply #1 on: April 11, 2024, 09:05:59 am »
Yes, you can reassign the Base Spline via maxscript in the following way (the index of the Object Node might differ based on your style):
Code: [Select]
$RailClone001.banode[1] = $Line001; I hope that helps.
