Author Topic: Can the 'Evenly' distance change depending on curvature of spline?  (Read 7311 times)
Adam86
Hi, might be asking a basic question (again) here but can you increase the amount of 'posts' for instance around a curve? i'm asking as I am creating a fence, which has long distances between posts, however around large radius i want the distance to decrease so it isn't as faceted. I currently have the evenly set to 1.8m and want to reduce it down to 800mm-1000mm. I'm playing around with conditional's and doubling up on linear 1s but feels messy to me.
thanks,
A
« Last Edit: May 29, 2018, 03:44:42 pm by Adam86 »
Re: Can the 'Evenly' distance change depending on curvature of spline?
« Reply #1 on: May 29, 2018, 03:47:52 pm »
Easiest would be to split to Two material ID- one is dense and one is not and have two generators for each of the style.
Adam86
« Reply #2 on: May 29, 2018, 03:54:38 pm »
Thanks Rokas, I was trying to keep everything as automated as possible, is there another way? almost need a 'reduce facet' option within the evenly option, and add a number there?
The method you have mentioned obviously works great btw.
A
« Last Edit: May 29, 2018, 03:58:17 pm by Adam86 »
