Author Topic: curved roof cut-out  (Read 3785 times)
Mennodepenno
curved roof cut-out
« on: August 09, 2019, 12:23:56 pm »
When creating a curved roof with an x and y spline, is there a possibility to remove a part for a balcony?
Or does that only work for closed splines with planar roofs?
Menno
Re: curved roof cut-out
« Reply #1 on: August 09, 2019, 01:41:20 pm »
Sure, You can. Please use clipping spline for this:
Hope this helps. Attached scene as well.
Mennodepenno
« Reply #2 on: August 09, 2019, 06:07:55 pm »
Ah yes, i got it working now.
Thanks Rokas
steve3duk
« Reply #3 on: June 30, 2020, 03:03:03 pm »
Hi. On a similar note I'm having problems with this setup. The rectangles are not cutting out from the main roof.
« Reply #4 on: June 30, 2020, 03:57:32 pm »
If Your could attach Your max scene we could take a look into it.
steve3duk
« Reply #5 on: June 30, 2020, 04:16:09 pm »
Thank you very much. Here it is.
« Reply #6 on: June 30, 2020, 04:28:12 pm »
Please set Macro Hierarchy checking to Two
Hope this solves the issue.
steve3duk
« Reply #7 on: June 30, 2020, 04:31:23 pm »
Brilliant. Thank you :)
