Author Topic: Help Me for building Bridge like this  (Read 8020 times)
JG2322
« on: July 18, 2014, 06:33:41 pm »
I was some project animation
create bridge like this attachment
Can You Help me to use railclone pro to solve this...
Re: Help Me for building Bridge like this
« Reply #1 on: July 19, 2014, 01:43:54 pm »
The logical approach would to use several Linear generators (with one or multiple RC objects): one for the main structure, other for the cables and so.
In the following post you can find some ideas.
http://forum.itoosoft.com/index.php?topic=1937.0
If need help with a specific part of the bridge, please don't hesitate to ask us.
JG2322
« Reply #2 on: July 19, 2014, 01:56:56 pm »
Thanks For your fast reply,
maybe i mean like this bridge...
i was difficult create arch in the bridge
can you help me...
i was new in use railclone...
thanks before...
« Reply #3 on: July 20, 2014, 09:46:22 am »
There are different ways to build this bridge. If you want to make it parametric (so, i.e. the distance between pillars can be changed), use several linear generators:
1) Structure: Start/End segments for the end pieces, Default segment in scale mode for the arc and Evenly for pillars.
1) Road. Just a simple linear generator with a Default segment (there are several samples in the Library).
2) Railing. See the library for examples.
Anyway, this case may be a bit hard to start with RailClone.
If you have not used the software before, i suggest you complete our tutorials before (starting by the Mansory Wall). It will help you to understand better the RailClone basic concepts.
OB
« Reply #4 on: September 06, 2014, 11:29:41 pm »
I think you need something like this :
https://dl.dropboxusercontent.com/s/lidtej0qomrz2di/shot_140907_002532.png?dl=0
The whole procedure of making arc of the bridge should rely on the height of the columns supporting it , railclone expressions can handle that , just control height scale of supporting columns by expression with a sinusoid or something like that.
You can do such funny stuff also :
https://dl.dropboxusercontent.com/s/rn5t344clf0yr2m/shot_140907_001842.gif?dl=0
