Author Topic: Vertical Bricks around windows  (Read 2488 times)
Cherami
« on: April 04, 2023, 05:14:36 pm »
I try to make a brickwall with a 2D Array and Clipping Area, with "vertical" bricks around all openings (windows for exemple). See attached files for more informations.
The clipping area is made up of several splines : a peripheral, and others that will "remove" the brick in places.
It works on the peripheral spline, but not on other splines
Is there a way to do that?
Regards,
Re: Vertical Bricks around windows
« Reply #1 on: April 06, 2023, 11:22:19 am »
A possible approach would be to assign different Material IDs to these spline segments (outer / inner vertical / inner horizontal) and handle these parts within individual Generators (using the Limits > Material ID feature). Please find attached the modified scene (230406_BrickWall_iToo.max).
Cherami
« Reply #2 on: April 07, 2023, 04:42:57 pm »
Thanks for the tips! It works well.
Best regards
