Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
cap end slats
« previous
next »
Print
Pages: [
1
Author
Topic: cap end slats (Read 6923 times)
RL1396
Newbie
cap end slats
on:
April 25, 2018, 01:26:47 pm »
when I make a floor, the slats of the end of the surface are cut. I wish there was a "cap" of achievement. Is there an option that allows it?
Last Edit: April 25, 2018, 01:41:26 pm by RL1396
Logged
Hero Member
Re: cap end slats
Reply #1 on:
April 25, 2018, 01:48:35 pm »
Welcome to the forums.
There is no such function in RailClone. You can try to use 3ds max native modifier "Cap holes"
Logged
RL1396
Newbie
Re: cap end slats
Reply #2 on:
April 25, 2018, 02:13:50 pm »
Thank you for your answer.
cap holes is a good solution but there's a problem with the texture. how can I do to have the same texture for the cap holes than the slats
Last Edit: April 25, 2018, 02:15:43 pm by RL1396
Logged
Hero Member
Re: cap end slats
Reply #3 on:
April 25, 2018, 02:33:05 pm »
It is probably Your multi material. Adjust it so blue material id is the same material as rest of the model.
I could examine Your scene further if You attached it here.
Logged
RL1396
Newbie
Re: cap end slats
Reply #4 on:
April 26, 2018, 11:23:54 am »
the file is too big for this forum (13,8Mo)
Logged
RL1396
Newbie
Re: cap end slats
Reply #5 on:
April 26, 2018, 11:27:12 am »
in the same way, I would like to be able to solve this problem with the tiles of this roof.
the roof is not perfectly rectangular, the edge tiles are not put in place and a cut appears. Is there a simple solution to clean this problem?
Logged
RL1396
Newbie
Re: cap end slats
Reply #6 on:
May 02, 2018, 10:14:50 am »
I can't solve the problem of the "cap holes" material.
Here's the sample file.
thank you in advance for your help
Logged
Hero Member
Re: cap end slats
Reply #7 on:
May 02, 2018, 10:29:20 am »
We have some parameters to play with:
Logged
RL1396
Newbie
Re: cap end slats
Reply #8 on:
May 02, 2018, 10:53:54 am »
ok.
Thank you very much
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
cap end slats
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
