Author Topic: cap end slats  (Read 6469 times)
RL1396
cap end slats
« on: April 25, 2018, 01:26:47 pm »
when I make a floor, the slats of the end of the surface are cut. I wish there was a "cap" of achievement. Is there an option that allows it?
« Last Edit: April 25, 2018, 01:41:26 pm by RL1396 »
Re: cap end slats
« Reply #1 on: April 25, 2018, 01:48:35 pm »
Welcome to the forums.
There is no such function in RailClone. You can try to use 3ds max native modifier "Cap holes"
RL1396
Re: cap end slats
« Reply #2 on: April 25, 2018, 02:13:50 pm »
Thank you for your answer.
cap holes is a good solution but there's a problem with the texture. how can I do to have the same texture for the cap holes than the slats
« Last Edit: April 25, 2018, 02:15:43 pm by RL1396 »
Re: cap end slats
« Reply #3 on: April 25, 2018, 02:33:05 pm »
It is probably Your multi material. Adjust it so blue material id is the same material as rest of the model.
I could examine Your scene further if You attached it here.
RL1396
Re: cap end slats
« Reply #4 on: April 26, 2018, 11:23:54 am »
the file is too big for this forum (13,8Mo)
RL1396
Re: cap end slats
« Reply #5 on: April 26, 2018, 11:27:12 am »
in the same way, I would like to be able to solve this problem with the tiles of this roof.
the roof is not perfectly rectangular, the edge tiles are not put in place and a cut appears. Is there a simple solution to clean this problem?
RL1396
Re: cap end slats
« Reply #6 on: May 02, 2018, 10:14:50 am »
I can't solve the problem of the "cap holes" material.
Here's the sample file.
thank you in advance for your help
Re: cap end slats
« Reply #7 on: May 02, 2018, 10:29:20 am »
We have some parameters to play with:
RL1396
Re: cap end slats
« Reply #8 on: May 02, 2018, 10:53:54 am »
ok.
Thank you very much
