Author Topic: Parking cars  (Read 4220 times)
JB3332
Parking cars
« on: November 13, 2025, 11:02:10 pm »
I am trying to use Raiclone to park cars. I created a simple linear array, and I added some empty geometry nodes to have some empty parking spaces. It is looking good, but the problem is the cars are not aligning correctly with the parking space.
I am using the evenly spaced value, but when I try to adjust the spline, some cars are aligned, others are not. And when I adjust the spline vertex to try to align all of them, right before they all fit correctly, they desapear and show a new series of cars but not aligned correctly.
It is like almost there but now.
Re: Parking cars
« Reply #1 on: November 14, 2025, 08:49:30 am »
I'm sorry to hear you're having trouble with it. It could be related to the Evenly > Justify option, but it's hard to say for sure just from the images. I’d recommend using a slightly different style setup that should help avoid the issue: set a Fixed Size for used Segments (cars) to match the parking space and keep Scale Segment option disabled. With Scale Segment off, RailClone only adjusts the Segment’s bounding box (the space used to position the next/previous Segment) without modifying the geometry itself. I hope this helps.
