Author Topic: wine shelf  (Read 7098 times)
DusanMNC
    • MNC studio
wine shelf
« on: September 28, 2025, 06:40:22 pm »
Hello everyone,
I am trying to populate with random bottles of wine this shelf (see attached), I have watched some similar tutorial found here but I doesn't work properly, maybe because the tutorial is too old. Anyone who can give me some workflow that I can try?
Many thanks.
Re: wine shelf
« Reply #1 on: September 29, 2025, 09:11:08 am »
You can use the Randomize Operator to control the percentage of empty segments. To achieve the grid placement, the Sequence Operator in "Increment at Y" mode with an alternating "translated" row should do the trick. Please find attached a sample scene showing a possible style setup. I hope this helps.
DusanMNC
    • MNC studio
Re: wine shelf
« Reply #2 on: September 29, 2025, 04:11:09 pm »
Thank you for reply,
I have check your scene and it seems easy, but in my case it's still complicated. When I add more bottles as "segment" it doesn't work any more. I just can't set up the right scaling (distance between the bottles).
Please find the scene attached.
Thank you for the support.
Dusan
« Last Edit: September 29, 2025, 04:56:39 pm by DusanMNC »
Re: wine shelf
« Reply #3 on: September 30, 2025, 09:34:12 am »
Hi Dusan,
As the size of these bottles may vary slightly, an alternative to adjusting the Padding values is to tweak the Fixed Size setting to match the grid while keeping Scale Segment disabled. For proper placement, you can fine-tune the Transform > Translation values as needed. Please find attached a revised scene where I’ve roughly adjusted these values. I hope this helps.
