Author Topic: Change multiple values with one Boolean Parameter  (Read 3522 times)
suppenhuhn
« on: March 06, 2020, 04:55:45 pm »
    Hi!
    I'm trying to get it managed how to  trigger multiple changes within my RailClone object with only Boolean Parameter.
    By that bool-parameter i'd like to trigger:
    • Multiple Selector nodes to switch their index from 1 ( bool=false ) to 2 ( bool = true )
    • A Sequencenode  ( 2 Elements A + B ) order from A/B ( bool=false ) to B/A ( bool = true )
    • To "inverse" the bool for i.a turning on/off a object form object-on ( bool=false ) to object-off ( bool = true )
    • or instead of the point above: a conditional check when bool == true then turn off objects A, B, C and turn on objects D, E, F
    Best solution would be when the conditional operator could handle boolean inputs as well !!
    I'd appreciate any hint where i should look into or what tutorial should i check out ... or..or..or :)
« Last Edit: March 06, 2020, 05:16:54 pm by suppenhuhn »
Re: Change multiple values with one Boolean Parameter
« Reply #1 on: March 06, 2020, 05:21:27 pm »
if I understand correctly, let's try this one for a start:
suppenhuhn
« Reply #2 on: March 06, 2020, 05:57:43 pm »
You did !!
The arithmetic expression + sequence into a selector was the key!
Thank you very much  8)
« Reply #3 on: March 06, 2020, 06:06:00 pm »
Glad to help.
suppenhuhn
« Reply #4 on: March 06, 2020, 06:15:41 pm »
But one more question:
When i'd like to "inverse" the boolean value trying to use this expression i got a error:
Code: [Select]
if (Input1 == 0 ) {
  return
1;
if (Input1 == 1 ) {
  return
0;
« Reply #5 on: March 06, 2020, 06:21:19 pm »
it should go like this:
RETURN
If(input1==0,1,0);
or
RETURN
if(input1==true,false,true);
suppenhuhn
« Reply #6 on: March 06, 2020, 06:27:35 pm »
MERCI !!! Do i read it right:   if input1 is 0 -> return 1 else return 0
Would be awesome when the expressions could handle javascript code
« Last Edit: March 06, 2020, 06:31:56 pm by suppenhuhn »
« Reply #7 on: March 06, 2020, 06:34:20 pm »
Yes, You are reading right.
Some useful documentation:
https://docs.itoosoft.com/railclone/style-editor/operators#Operators-Arithmetic
