Author Topic: Preserve original normals on sliced geometry  (Read 3146 times)
UB8512
« on: June 27, 2016, 12:22:41 pm »
it is possible to preserve original normals on segments which are sliced? I am using edit normals modifier on original piece of tile =>I set all normals to unified and then I select top polygon face normals and orient it straight top to produce correct flat reflections (not bended) ?
example screens
Re: Preserve original normals on sliced geometry
« Reply #1 on: June 27, 2016, 02:58:15 pm »
Thanks for contacting us. I'd recommend trying to change the Operate On mode to Quads instead of tris. This may help to remedy this behavior.
If that doesn't help, if you could upload your sample scene that would be great. I'm having trouble reproducing the behavior here.
Many thanks!
UB8512
« Reply #2 on: June 27, 2016, 03:54:27 pm »
Thanks Paul, here is the 2014 corona scene
« Reply #3 on: June 27, 2016, 04:24:04 pm »
Thanks for the file. It seems that this is not a RailClone specific problem. I get the same results if I cut the tile using a Slice modifier. Instead of manipulating the Normals could you flatten the top by assigning the polygon a different smoothing group value? In my tests this seemed to work fine.
Many thanks!
UB8512
« Reply #4 on: June 27, 2016, 04:42:19 pm »
 8) put that top polygon in diff. smoothing group works ;) , I was too aimed only at normals  :D. THX.
